Getting up to 20 deg. of knock
Old Aug 26, 2003 | 06:58 PM
Euro749's Avatar
Been having this problem for a long time and now I really want to fix it. I was loosing timing like crazy down to 14 deg. during WOT and it's been killing me in power. I would get up to 6 deg. during idle.
I have the lt4 knock module in there, but can't really tell if it's real knock or false. Has anyone had a bad knock sensor? or a block sensor?
I have FLP headers with a 398 Stroker. NO exaust leaks, and no AIR with capped EGR. I am planning on replacing the sensors soon, but wondering if it could be something else
any suggestions?
thanks
Darko
Old Aug 26, 2003 | 08:03 PM
96speed's Avatar
If you are getting a constant 6* at idle or the retard goes up with the revs (just stabbing the throttle) your knock sensor is probably bad.
Ryan
Old Aug 26, 2003 | 11:08 PM
Josh-'04 GTO's Avatar
Hopefully you are not experiencing real knock. I would splash in some 103 octane unleaded and see if anything changes. If not, then you can be reasonably sure its false knock.
Any vibrations or rattling going on that could be setting off the knock sensor?
Old Aug 27, 2003 | 06:19 AM
96 WS6's Avatar
Try race gas, if it persists it's fake. It sounds like a bad knock sensor. You might to go under there and check if the knock sensor is loose or rattling around.
94Maroz28
Oct 27, 2015 04:38 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
whitehooptie
Aug 10, 2015 07:02 AM
