Getting the fuel pump to turn on...
My car has been sitting for over a year... I am putting to the motor back in tonight what i need to know is, is their a way to jump the fuel pump so that i can get the fuel out of the tank without dropping the tank...
Originally posted by twdz28
thanks, that would be great if someone could...
It will be approx 3" from the PCM itself, just hanging there. Connect this wire to the positive of the battery and that will run the pump as long as its connected.
Originally posted by DR.ZED
If you check right beside the PCM, where the wireloom enters it, there will be a a wire (only one), sitting there dangling. It has a connector at the end of it.
