getting compression ratio??
Old Apr 21, 2006 | 11:28 AM
silentsprintero's Avatar
mods in sig but i don't have flow numbers on the heads. is the only way to find my compression to take the heads off and get the flow numbers? stock is 10.4:1 and its just a small port job, do you think it affected compression much?
-Chris
Old Apr 21, 2006 | 12:05 PM
Type_O_Negative_1320's Avatar
Re: getting compression ratio??
Flow numbers have nothing to do with compression. What you would have to do is pull your heads and CC the chambers (fill them with a measured amount of liquid) to see how big they are. Then go here and punch in the numbers to figure out the compression ratio.
If it's just a light port job and you didn't have the heads milled or anything, I wouldn't worry about it.
Old Apr 21, 2006 | 02:47 PM
"White Knight"'s Avatar
if it was a port job, don't worry about it, it will be just be a smidge lower and effect nothing
Old Apr 22, 2006 | 12:30 PM
awsome thanks, last thing i needed to get tune
-Chris
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
surreybrad
Sep 29, 2015 09:00 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
