Getting clutch info straight...
Old Aug 5, 2003 | 01:34 AM
joshp14's Avatar
I have been reading up on clutch threads for almost 2 hours now. I have concluded that the SLP clutch is the best for my application. But, I'm am still pondering on some things...
What is the difference between the LT4 and the SLP clutch?
If it's the same, can I get it elsewhere cheaper?
I read the names TByrne and Justin Cromer in some threads, and how they sell these clutches cheap...as little as $288.
Any info is appreciated. Obviously, I would like to pay the least amount of money for the disc, PP, and TO bearing.
Old Aug 5, 2003 | 01:45 AM
Kronos94Sleeper's Avatar
i got a new lt4 clutch off e-bay for 300 bills
Old Aug 5, 2003 | 02:01 AM
joshp14's Avatar
Also, if it's any relevance...I have a 95 TA with 57K, original clutch, clutch engages at the top of pedal, can't smell anything, still get a 1-2 scratch, don't know how to tell if it's slipping, but my dad told me it did when he nailed it when he drove it.
Old Aug 5, 2003 | 02:02 AM
RedPhenx's Avatar
i got centerforce dual friction for about 300 also... not any more stiff than stock. and grips a lot better.
edit: 57k isnt a lot of miles... but you can tell if it slipping if the rpms rise with no corresponding movement.. usually easier to tell at WOT
Old Aug 5, 2003 | 02:06 AM
D James's Avatar
I'm replacing mine right now and I didn't get any slipping or bad smell, just once in a while it would make a grinding niose from takeoff, more so if I let the clutch out at a higher RPM, after removing the thing, I can't believe it held up, the spaces between the pads were all worn away in some spots, and the rivits were just starting to touch. I've even been taking it to the track, seemed OK until just recent. Mine engaged right at the very top also, not much difference between engaged and not, so yours is probably on its way out also. I also noticed it was hard to spin the tires through 2nd gear, before it was easy, so maybe mine was slipping but I didn't notice it. Id keep an eye on yours
Old Aug 5, 2003 | 02:09 AM
joshp14's Avatar
I have been, more so now though, just had it serviced and the GM dealer said it was fried and going out. I dunno whether to wait until it goes and try to get as much life out of it as possible, or just get a new one.
yea, thats what mine is doin, i cant chirp any gears any more, and its hard to peel out off the line, i gotta rev it to like 3k+ to peel out, before it would peel out when i got on it wot off the line. oh well, im gettin mine this week and its goin in right away. the only thing that sucks is my cat also took a ****. oh well its just money right???
Cisco
colts0455
Jul 8, 2015 12:21 AM
blkWidow
Apr 21, 2015 01:56 PM
BigWil
Mar 29, 2015 12:24 PM
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
