Getting 2 codes, think it might be O2?
Old Aug 8, 2003 | 02:39 AM
lt1_forever's Avatar
i have a '97 SS and a week ago the ses light came on. i scanned it and gave me codes P0174 and P0430. the car is kinda running like **** and it is loosing a lot of hp. i think it might be the passenger side O2 but not sure. i was wondering if anyone else might be able to give me there opinion.
Old Aug 8, 2003 | 02:42 AM
Cmr0z28's Avatar
P0174 System too Lean (Bank 2
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
Old Aug 8, 2003 | 02:44 AM
i know what the codes or i have the camaro book, but i'm sure this could be other possible problems other than an O2
Old Aug 8, 2003 | 02:48 AM
Cmr0z28's Avatar
try replacing the o2s and see what happens, maybe the cat is clogged?
Old Aug 8, 2003 | 02:22 PM
should i replace the o2 in front of the cat or after the cat?
Old Aug 8, 2003 | 03:05 PM
You need to attack one problem at a time. The P0174 means the system is running lean, and the PCM can't correct for it. Could be a bad O2 sensor, but it could also be an exhaust leak, misfires, vacuum leak, etc. If you had a scanner, you could check the long term fuel corrections, to see when/where the problem is most severe, and if it is affecting both sides of the engine. That might give you a clue to the source of the problem.
Another approach is to switch the left and right side pre-cat sensors. If the problem follows the sensor, it is a sensor problem. If the problem stays on the passenger side, it is something besides the sensor.
If the A/F is buggered up on the passenger side, the cat might be having a problem dealing with it, and that could be affecting the readings form the after-cat sensor on that side. Fix the "lean" condition first, then see what happens with the after-cat sensor/cat effciency problem.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
