Getting 12volts on the distributor reference low wire
Old Apr 28, 2003 | 02:20 PM
94FlamdS10Blazr's Avatar
now should I be getting like 4-5 volts negative on this? Im getting 12 volts negative. I just did a new optispark and now I got this and we all know 12 volts - on the coil = no spark. So thats where Im at right now. Is it another dead optispark outta the box? That would suck! I pulled it all apart again down to the optispark to see if the coil wire was shorting somehow on the water pump but it still wont crank
Old Apr 28, 2003 | 05:05 PM
well I got another optispark coming. does anybody think this is it? anybody?
Old Apr 29, 2003 | 07:12 PM
I need some help here guys. I swapped the optispark and it still wont fire up. Im not getting the right signal from the optispark or the ignition module. You think the computer is gone? You think I got bad grounds what?
Old Apr 29, 2003 | 11:31 PM
im not getting any help with this am I?
I swapped the Optispark again and still nothing. I got no fire at all.I didnt volt check it but Ill bet its still getting 12+ instead of 12-. The "new" one looked used so I sent it back and reinstalled the 2nd one being as It looked new. The blue o-rings had the paint worn off the 3rd optispark, thats why I said it looked used.
I talked to Brian over at pcmforless and he said that some guys are getting dead optisparks straight outta the box from GM. Maybe thats it. I dont know
TTT
Old Apr 30, 2003 | 10:42 AM
TTT
DirtyDaveW
Dec 1, 2016 05:37 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
brentbrowning01
Dec 3, 2014 10:36 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
