general pushrod question
Old Oct 1, 2004 | 04:06 PM
30thannZ28's Avatar
I just wanted to know how many of you have pushrods that are NOT either 7.20" or 7.15". I only want to know this because mine are too long and it seems the only other size you can buy are 7.15". Thanks
(let the ***** jokes fly...)
Old Oct 1, 2004 | 05:44 PM
chrism400's Avatar
Re: general pushrod question
__________________
*1997 Camaro Z28 6-speed True 30th*
Lloyd Elliott heads|233/239 112 Cam|1.6RR|Jet Hot LT|MADWOLF tune|OBD I|Comp R lifters|CAI|52mm TB|Mufflex Y pipe|Hooker catback|spec stage III clutch|MSD 6A|MSD coil|MSD wires|OTVC kit|NGK TR55|Walbro fuel pump|30# injectors|Cloyes timing kit|CSI pump|SLP short throw shifter|lou's short stick|160 stat|LT4 KM|drilled/slotted rotors|pullies|poly susp|BMR STB|BMR subframes|BMR LCA|BMR PHB|T/A girdle|scanmaster|!TB|!EGR|!AIR|!CATS|!CAGS|Primo sound system|etc.
I don't know the answer to your question but what does that beast run if you don't mind me asking?
Old Oct 1, 2004 | 06:18 PM
30thannZ28's Avatar
Originally Posted by chrism400
__________________
I haven't taken her to the track yet cause my pushrod length is currently incorrect and my dumb *** has had a pushrod length checker THE WHOLE TIME I was doing these mods and I didn't measure, I just assumed it would require stock length pushrods. boy was I wrong. I believe I need 7.15" ones, but I just wanted to see if ANYONE out there was running any other length other than 7.2" or 7.15" so I can see if the 7.15" will suffice without measuring. No website even sells any other length besides those two measurements. I will have track times once I get the right pushrods and my 9 degrees of knock tuned out. I'm gonna buy a laptop and LT1 edit the knock out (not that madwolf's tune was bad, it just needs tweaking) and I would like some 4.10's for my rear, but I'm scared I won't install them correctly. I'm not paying a shop to install those....
P.S. nice mods, how do you like the hydra rev kit?
Old Oct 1, 2004 | 09:05 PM
rskrause's Avatar
Moderator
You need to measure. Then get a hold of Manton Pushrods for the proper length. Great product and great service. www.mantonpushrods.com/
Rich
Old Oct 2, 2004 | 12:13 AM
chrism400's Avatar
Thanks! It seems to be working well so far. As for the hydra-rev, I don't know if it's helping or not because I installed it when I installed the cam. I can tell you this, it pulls all the way up to the 6400 rev limit. It seems to me that 224 duration isn't very much and I'm amazed that it maintains power to that level. Maybe the hydra-rev has something to do with it. I just remember seeing an article awhile back where hp started to fall off with hydraulic rollers because of their mass. The hydra-rev helped to keep the lifters controlled at higher rpms without destructive spring pressures. It's kind of a pain to install with the heads on but it can be done in about 2 hrs. I got the thing for free so I figured what the heck - I could use the insurance.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Mar 1, 2015 01:33 PM
ChrisFrez
Jan 18, 2015 08:05 AM
dansam
Jul 20, 2002 01:10 PM
