Gear whine and noise, any cure?
Old Jun 11, 2003 | 03:14 PM
RTICWOLF's Avatar
Question Gear whine and noise, any cure?
I had my rear end rebuilt (not by choice) and they had to use Richmond gears since the GM ones were not available. They did warn me about the noise, but I am hating it!
The guy said that synthetic fluid may help, but he did not know for sure.
So, now that my 500 mile break in period is over, I changed the gear oil (took the cover off) to Mobil 1 75/90 and added the GM LSA into the rear end as well. The rear end sounds the same...drives me nuts!
Is there ANYTHING I can do to help? Any ideas of what may work (outside of a new set of gears or a 12-bolt that is)? Has anyone had this issue and figured out something that worked?
I would appreciate any and all input, who better to ask then fellow F-body owners?
Thanks!
Old Jun 11, 2003 | 03:18 PM
hairbear21's Avatar
This is an inherant problem with these cars, but if you want, get some dyanmat and throw that on the back hatch area, and it should take care of a lot of it.
Old Jun 11, 2003 | 03:23 PM
RTICWOLF's Avatar
Hmmm, never thought of that! Not a bad idea!
Sheesh, we should not have to deal with this anyway, damn this kinda thing makes me mad......I would have opted for the 12-bolt had I had the $$$$ at the time.....
Anything else that someone has tried?
Old Jun 11, 2003 | 03:28 PM
97FormulaWS-6's Avatar
well, I can't give you a total cure all.. but for #1 I'd take it back and have them go through it and make sure all the specs are still what's they're supossed to be and makesure the pattern is wearing in good.
I had a nasty noise and vibration in mine for about the first 700 miles.. I check everything over and over again, even replacing the DS... it ended up the pinion bearing preload had loosened up or wasn't tight enough to begin with.. I tightened it up, and now I have almost NO whine at all, just a slight amount when I back-load the gears.
but once you ahve gear whine, if you can't figure out what's causing it... it's never get better, only worse, and once you have about 1500mi on a set.. they're pretty much worn in and it'll be ther forever then.
Here's a website that helped me figure out what mine was/could've been. http://www.dippy.org/svcman/sm03.html
Old Jun 11, 2003 | 03:29 PM
BUBBA's Avatar
You might want to get hold of Drive Train Specialist (DTS) in Michigan or Ring and Pinion, in Washington State.
My guess is that you are stuck with the noise unless you swap out the gears.
At least you might get a good price on some new ones. And if you have other than 3.73s on an A-4 or 4.10s on M-6, I'd also suggest going with those rations.
And get GM OEMs if possible, even over Motive.
I understand they are the quietest.JMHO
And...have them install with RATECH solid shim spacers in lieu of the crush sleeves.
PCLZ28
Dec 24, 2015 05:19 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Fatdog2
Feb 12, 2015 12:24 PM
ddr698
Jan 9, 2015 10:05 AM
squarehead
Nov 21, 2014 08:02 PM
