Gear Swap
Old Mar 7, 2003 | 08:04 AM
TaylnStorm's Avatar
Question Gear Swap
I just bought my '95Z last week and found out I have the horrible 2.73 gears. Anybody know what the best way (cheapest way) to get some 3.42 or 3.23's. Should I just get a completely new rear. I know a guy selling a 10-bolt out of an '86 IROC with 3.42's, will that work without breaking or compatability problems? I'm going to the track tonight for some stock times. I'll post how I do with those crappy gears.
Old Mar 7, 2003 | 08:27 AM
IDOXLR8's Avatar
Is your car a 3 channel or 4-channel ABS rear?? If it is 3 channel I will be selling my rearend out of my 93 Camaro with a Strange 3.73 gear. Let me know. I will let it go for $350.00.
Old Mar 7, 2003 | 08:36 AM
ibanez6rg's Avatar
For a stock car, you won't need a new rear-end.
Old Mar 7, 2003 | 04:42 PM
TaylnStorm's Avatar
No idea, I heard of a carrier but not channel. How do I know what I have. I'm a GU2 package not GU6.
Old Mar 8, 2003 | 03:04 PM
TaylnStorm's Avatar
TTT...
And I do need a new rear, because I have a two series carrier...it will be a lot cheaper just to get an entire rear end rather than buying Richmond 3.42s or 3.73s for a two series carrier, plus an installation package...
Old Mar 8, 2003 | 10:09 PM
PoorMan's Avatar
I had 2.73 in mine too. They came in all convertibles I believe. Anyway, I bought some used 3.42 Motive gears from another board member here for 100.00. SLP 3 series carrier for 100.00 and a new reluctor gear for 20.00. The install cost me about 200.00 and that included a new pinion bearing. So it cost me about 450 to have it done with the lube and all. It will cost use about 250.00 in just parts. But if you don't have a bearing press, dial indicators, ect. then pay the labor.
Jeff D.
Old Mar 9, 2003 | 01:41 AM
TaylnStorm's Avatar
I was browsing SLP's website, but I can't find the 3 series carrier you spoke of. Where else can I find such a product at that price?
Old Mar 9, 2003 | 11:44 AM
PoorMan's Avatar
They were take off carriers from standard Z28 and Trans Am that they upgraded when doing the SS/Firhark conversions. Try here:
http://www.lmperformance.com/683/2.html
Jeff D.
Old Apr 16, 2003 | 05:30 PM
robb4964's Avatar
Re: Gear Swap
www.gearsareus.com You can get all the stuff you need "bearings shims gears " brandnew for 220 dollars ........thats the new gears and install kit and it is well worth it
Old Apr 17, 2003 | 04:04 PM
Fast Caddie's Avatar
Strange makes gears for both, whether it be a 2 or 3 series. So you can keep the 2 series carrier and get whatever gears you want. I've got the 2.73s too and will be moving up to 3.23s or 3.42s here soon.
http://www.thunderracing.com/index.c...ategoryid=1062
Scroll on down and you'll see what you can get.
Zee man
Feb 12, 2015 07:07 AM
rocketman051894
Jan 30, 2015 03:23 PM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
