Gear Oil?
Old Feb 23, 2005 | 11:34 AM
wayfastwhitey's Avatar
Gear Oil?
I am about to change the gear lube in the rear end of by 94 Z28 A4 with 3.23 gears. My question is if I use synthetic gear oil in my rear end that already contains limited slip additive do I still have to use the GM limited slip additive? Also what is a good gear oil?
Old Feb 23, 2005 | 11:41 AM
FastZinTennessee's Avatar
Re: Gear Oil?
Mobil 1 75w90 gear oil + GM limited slip additive found at the GM parts counter has always worked perfectly for me.
If you buy gear oil that already has the limited slip additive in it, I would try it out first without adding anything. If it squeals/pops or otherwise acts like it shouldn't then go to the dealer and get some additive.
Old Feb 23, 2005 | 12:51 PM
Spinner's Avatar
Re: Gear Oil?
Im using standard 75w90 cheap stuff and GM limited slip additive. Works fine.
Old Feb 23, 2005 | 01:36 PM
hotrod18_69's Avatar
Re: Gear Oil?
Same here...
Old Feb 23, 2005 | 01:43 PM
"White Knight"'s Avatar
Re: Gear Oil?
I run 80W140 it provides better protection for the ring and pinion gears under hard launches.
does 90W-180 oil exist?--cause for some reason those numbers are stuck in my head. I don't know why though, maybe i read about it--or maybe i'm just crazy and it doesn't exist.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
redz_02
Jul 24, 2002 09:42 AM
