Gasket Package for Cam Change
Old Apr 27, 2008 | 08:20 PM
  #16
96capricemgr's Avatar
You could but then you might have to look at adding on the oil cooler adapter gaskets since I bet you have to drop that to loosen the pan, is cheap so this is informative not a critical comment.
I tend to look at things like the conversion gasket kit because between myself and a few friends we have a fair number of LT1s and the spare parts seem to come in handy OFTEN.
I currently own two wagons and the sedan and a good friend and his wife both daily drive modded sedans, the list goes on. Seems somebody always needs something.
Old Apr 27, 2008 | 08:27 PM
  #17
my96z's Avatar
Ahh I was wondering what that gasket was for, it looked odd to me, couldnt place it. I dont have an oil cooler. So I think the timing cover will suffice for me.
FWIW I compared those gasket kits and they are a few dollars cheaper at autozone (cept the conversion set) as are the Mr.Gasket 5716 head gaskets I am going to run.
Thanks again for the help Dwayne.
P.S what are you using for a timing chain? I would like to go with a single roller set up, that fits in the stock cover. Isnt that what the Lt4 kit is? (Not extreme duty)
Old Apr 28, 2008 | 07:54 AM
  #18
JoeliusZ28's Avatar
Originally Posted by 96capricemgr
Reason I recommend the full bottomend gasket set is so you can pull the pan completely and replace the oilpump driveshaft with an all metal one and consider a higher pressure spring in the stock oilpump. I wonder how many LT1s have spun bearings because owners who thought they were careful dropped debris in the oilpan. I like to completely remove the engine, then again that is farily easy on my car.
wouldnt it also be a good idea to add 4-bolt main caps if you are pulling the engine for the swap?
...im tempted to go that route now when i do mine in a couple months.
Old Apr 28, 2008 | 08:06 AM
  #19
No, 4-bolt main caps is a BIG step beyond requyiring a lot of additional machining, some of which many engine rebuilders are not even capable of. Every shop should gbe able to line hone but new caps requires a line BORE and not a lot of shops are capable. The 2 bolts work well for most applications.
Old Apr 28, 2008 | 08:08 AM
  #20
JoeliusZ28's Avatar
ah well then nevermind, i was under the impression that was an easy swap-out. guess i was wrong.
Old Apr 28, 2008 | 01:30 PM
  #21
Slowmaro95Z28's Avatar
I just picked up my gaskets today for Auto Zone. I got the timing cover gasket which came with water pump gaskets and O rings along with what looks to be a rear main seal. I also got a simple Intake gasket which came with a throttle body gasket and new injector O rings. The total came to $27.
Old Apr 28, 2008 | 02:10 PM
  #22
Maybe I should have said oil filter adapter/cooler because they are very similar.
I run a stock chain, I think it completely illogical the way everyone insists on "upgrading" a part that does not break and in doing so spend a lot of money and compromise reliability and repairability with electric pumps if they go with gen 1 chains.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Queens94z28
Dec 20, 2014 09:11 PM
