Gasket name on top of throttle body? why is it there?
Old Jan 12, 2006 | 06:40 PM
Critter's Avatar
Arrow Gasket name on top of throttle body? why is it there?
took apart tb today to clean it and the intake. noticed the gasket on the top of the throttle body was in really bad shape. under the plate on top has 6 star type screws in it.
what is it called because i can't find one?
what is the cavity under it for?
Old Jan 12, 2006 | 09:51 PM
speed_demon24's Avatar
Re: Gasket name on top of throttle body? why is it there?
I think its for the IAC if i remember correctly. I just used RTV on mine and it sealed fine.
Old Jan 12, 2006 | 10:03 PM
No... the plate covers the passage that leads from a port in front of, and between the TB bores, that leads to the upper hose connection on the passenger side of the TB. That hose supplies air to the passenger side valve cover, to be pulled through the crankcase and lifter valley by the PCV valve on the driver's side of the intake.
The gasket is available in a "kit" that includes the gasket for the top cover plate, and another for the lower coolant/IAC plate. From Shoebox's website:
94-97 top and bottom throttle body gaskets:
AC-Delco # 40-743 17113074
$4.87
Old Jan 12, 2006 | 11:55 PM
Critter's Avatar
you da man thanks
Old Jan 13, 2006 | 12:03 AM
No.... Shoebox is da man.....
HectorM52
Jul 30, 2017 11:46 AM
Fatdog2
Feb 13, 2015 08:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
