gas smell....
Old Apr 27, 2006 | 11:46 AM
98silverz28's Avatar
gas smell....
i have a gas smell. im thinking its the evap system. i just need to know where the canister is located and what all do i need to remove it? although i think its the evap system, is there anything else i should check? and anyone have step by step on how to replace it?
thanks!
Nathan
Old Apr 27, 2006 | 11:51 AM
Re: gas smell....
Driver's side rear fender, near the gas fill pipe. There's a plastic panel on the fender liner for access.
Old Apr 27, 2006 | 01:28 PM
Re: gas smell....
what do i do once i get there?
Old Apr 27, 2006 | 02:42 PM
OBE1 95Z28's Avatar
Re: gas smell....
Verify it isn't something simple like a hose came off or is damaged.
Old Apr 27, 2006 | 02:56 PM
Re: gas smell....
Where does the fuel smell the strongest.... front of the car or the back? A canister problem will show up in the back. Most common problem would be rotted hoses connecting the top of the fuel tank to the canister. Unfortunately, those lines are impossible to see with the tank in place. You need to try and pin down the location before you start taking anything apart.
When you remove your fuel cap, it there ever any pressure in the tank that vents when you open the cap?
If the smell is in the front of the car, start inspecting for leaks in the fuel lines.
Old Apr 27, 2006 | 10:59 PM
Re: gas smell....
seems like when im driving the car... its aroudn the area of my console maybe behind that a bit...so i guess that would be considered the back. its pretty hard to place
Old Apr 28, 2006 | 01:22 AM
Lower's Avatar
Re: gas smell....
If there is none, then what's your diagnosis?
Old Apr 28, 2006 | 02:25 AM
ibringdarukus's Avatar
Re: gas smell....
yo i got a GAS SMELL also in my 94 Z28 Camaro.. what is that about? my mechanic said i didnt have a LEAK so i should be fine.. but i still SMELL it from time to time.. TOWARDS the front, and the back sometimes.. yeah hlp
Old Apr 28, 2006 | 11:12 AM
Re: gas smell....
Might be a sign that the hoses between the fuel tank and the pressure relief valve are cracked. That would keep pressure from building up in the tank. With a closed system like ours, it isn't unusual to get a bit of pressure out of the tank when you open the cap.
I had a problem with a loose hose after my fuel tank was removed and reinstallled (to add a sump). When I stopped at a light with the window open, the smell of racing fuel was enough to bring tears to my eyes. Simply repairing the leaky hose solved the problem.
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
