searched~Oh jeez, need CSR wiring help quick.
Old Apr 27, 2006 | 11:44 AM
firebirdStud's Avatar
Exclamation searched~Oh jeez, need CSR wiring help quick.
Well, I went on their site, and no wiring instructions. Nothing. So, I have the warning kit from spartus on impalassforums.com, GREAT KIT! I am gonna use it, and it employs a relay for that. But, for the actual power to the pump, how do I do that? I would like to have it so it is switched on by the motor running, and I also want to control it by just a switch. Is there a way to do this so that when the engine is running the switch has nothing to do with the pump, but when the engine is off I can use the switch to keep the pump running? Or am I just dreaming here? I have the link to the guy who wired his CSI pump up through the AIR relay. Should I just do that? Or is a realy needed for the pump? All CSR says is to have a fuse no bigger than 15 amps, end of story. So, what have you all done in this department?
THanks
Cody
Old Apr 27, 2006 | 12:00 PM
JasonK94Z's Avatar
Re: searched~Oh jeez, need CSR wiring help quick.
http://ken.lowrance.com/projects/CSIwaterpump/
Old Apr 27, 2006 | 08:46 PM
thanks, but I have that one already. I think I figured out how to do it with two relays, but just lookin to see if anyone has tried this already.
Old Apr 28, 2006 | 05:43 AM
Guest47904's Avatar
Guest
Explain what you are trying to accomplish and the parts you have now and I'll design it for you.
Old Apr 28, 2006 | 11:17 AM
Well, Is there a way to do this so that when the engine is running the switch has nothing to do with the pump, but when the engine is off I can use the switch to keep the pump running? Therefore, I want to be able to have a signal tell the pump the car is on and to run, or when there is no signal I can use the switch to activate it. I have two relays, which I think I should be able to accomplish this now. Each relay has the switched power in, relay 1 has the switch, relay two has the ignition. That way, when ignition is on, it doesn't matter where the switch is at it will still run. Otherwise I may forget to turn the damn pump on and blow the motor. Make sense?
phatbasslines
Jan 13, 2015 05:03 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
