Gains to be expected from 383 Stroker?
Old Dec 20, 2004 | 10:10 PM
cz28s's Avatar
What type of gains should i expect from my 383 stroker kit. I mean typically what type of numbers do these usually put down. I have only a couple of toher mods and they are in sig. Let me know what i should look for. extra 50? maybe 100? Also tpyically what type of times and traps speeds do they ususally put down with the 383. Thanks Cory
Old Dec 20, 2004 | 11:02 PM
sleepy_z28's Avatar
Re: Gains to be expected from 383 Stroker?
Gonna need more info about what cam and what heads before any reasonable guess can be made.
Old Dec 20, 2004 | 11:03 PM
Spinner's Avatar
Roughly 1-2%hp, and 9-10% more TQ then a 350 given the same setup. The potential is all in the heads, and you've got to go big to feed a bigger motor.
Old Dec 21, 2004 | 10:05 AM
cz28s's Avatar
stock heads and cam, do i need to put heads on, I dotn wanna spend 1000 bucks on em. Or do i have to? Any other good prices on a set of heads or will porting mine out work as well. Thanks Cory
Old Dec 21, 2004 | 11:31 AM
ejfagala's Avatar
1G for a set of LT1 heads will get you junk. Porting your stock heads is the cheapest way to go but that will cost more then $1000 for a good stage three. A good set of after market CNCed heads to work with a 383 would be beteen 2-3 Gs.
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 22, 2015 02:03 PM
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
