fusebox help
fusebox help
ok i am trying to rehook up the fans through the factory wiring and have noticed some relays are missing from the box.. does anybody have a pic of the external engine fusebox and a list to ell me what is what? it sounds dumb, but whoever put this car together before i got it did a hackjob with the wiring and part of the harness that goes into that fusebox is from a v6 camaro so any help would be extremely appreciated.. thanks
mike
p.s. i did a search and couldnt find anyone with an actual diagram of how the relays/fuses are laid out in this compartment ..
mike
There are slight variations from year to year. There is a diagram of the underhood convenience box, with all components labeled, in your Owner's Manual. If you don't have a Manual, you can access it online using this link provided by Shoebox:
http://shbox.com/pdf/manuals.html
Racr_X
Jul 10, 2006 11:29 AM
