Fuse problem of DOOM!
Old Jan 6, 2006 | 05:01 PM
SK3TCH9's Avatar
Ok, here's whats up. My 96 Z28 was overheating so I checked the fuse for the fans and it was blown (20 amp fuse) so to get to Autozone for more fuses I changed it out with a 7.5 amp fuse, which actually made it run perfect. Now I replaced it with the 20 amp and its gone to hell, the headlights are on when they are turned off, on the dash my left turn signal is showing on all the time unless I turn on the emergency signals. When I turn on the lights the 2 high beams are dimmed and the passenger low beam is on. When I turn the high beams on the driver side lights are totally off and the passenger work fine. Also when the lights are on the windshield wiper doesnt work.
I found out also that I have a vacuum hose or something (very bad with cars unfortunatlely) that has a leak and I can't find the damn thing again to fix it..but I can hear it! Does anyone have any idea how to fix this because nobody can look at it for 2 weeks in this area. Its been like this since Hurricane Rita , I had to wait 2 weeks for an air intake system to be put back in when I ran over a tire. Eitherway, I'm carless and would appreciate some help please.
I've read on the boards that if the vacuum is lost that it causes shorts so maybe thats why it messing with my fuses? I don't know..so..freaking..confused... ARGH!!!!!!
Old Jan 7, 2006 | 02:38 PM
SK3TCH9's Avatar
Re: Fuse problem of DOOM!
ttt
Old Jan 7, 2006 | 06:37 PM
97s10ondubs's Avatar
Check to see if any wires are touching the exhaust, any wires grounding out, clean the grounds...i've heard of using a propane torch and opening the gas and running it along the vacuum lines while the car is running, when the idle picks up, you found the leak.
Old Jan 10, 2006 | 01:37 PM
SK3TCH9's Avatar
Well, the ground was fixed. Apparently the dumb **** in my car last was well..dumb so they had to fix things. Now here is the problem...
I HAVE TO GET THE COMPUTER REPROGRAMMED AND ITS GONNA COST 400-500 DOLLARS AHHHHHHH!!!!
>takes out a small town with my car<
Old Jan 10, 2006 | 04:10 PM
madz28.com to get it reprogrammed a lot less than 400...
Old Jan 10, 2006 | 04:15 PM
SK3TCH9's Avatar
Well..they just sat me down and said that I need a new computer, but to have the dealer diagnose it first. 300 for the new computer, 100 for reprogram, 75 for diagnosis, 100 to put it in. Lame...just lame. They stated that they could be wrong so don't waste the money on the computer yet..joy.
Old Jan 10, 2006 | 04:17 PM
SK3TCH9's Avatar
madz28.com isn't working when i put it in the browser. Oh well.
Old Jan 10, 2006 | 04:28 PM
try it later, something must be up w/ the server...
Old Jan 13, 2006 | 03:29 AM
SK3TCH9's Avatar
ok, the official diagnosis is....>drum roll< a wire was rubbing the side grounding out...WOOT! It ended up being 257 which is much better than the original 437 they quoted me. Also something that is freaking out on the EGR is gonna be replaced for free because it was recalled!!!! So yeah, car is good now. Just need a working air conditioner.
Old Jan 13, 2006 | 08:54 AM
ding ding ding, what do i win?
Red Hawk 94
Mar 18, 2019 04:03 PM
eanhl2004
Apr 4, 2015 12:01 PM
fpete1992
Dec 11, 2014 03:51 PM
JSK333
Sep 9, 2002 10:33 PM
CLEAR
Aug 30, 2002 07:49 PM
