Fun with headers
Old May 1, 2005 | 08:54 PM
cb94ta's Avatar
Fun with headers
I'm installing my pacesetter long tubes, everything was going ok, a little slow but okay, untill now I can not get the passenger side bolt holes to line up at all and the damn egr tube won't line up right for anything, what the hell am I doing wrong?
Old May 1, 2005 | 09:00 PM
tagz's Avatar
Re: Fun with headers
The EGR would not line up for me either? I'm assuming you have an auto and the dipstick tube is in the way? Nothin you can do about it... its too close to the header to make a bend. i blocked mine off.
Old May 1, 2005 | 09:01 PM
lt1srule's Avatar
should put the egr tub in last.After the header bolts are in.you take out the dipstick tub then put it back in after headers are in..small 10 mm bolt holds dip stick .not hard .had to do it this way on mine ..
Old May 1, 2005 | 09:12 PM
cb94ta's Avatar
Thanks, I was going to block the egr off, but the guy I got them from on ebay has screwed me and a month has gone by and I still don't have the plates, so I I'll try to bolt them in, so far the install hasn't been to bad exept for this and a few minor things(finding out draining the radiator does not get rid of all the coolant by pulling the knock sensor and thereby washing my garage floor with antifreeze)
Old May 1, 2005 | 09:46 PM
KillWhitey's Avatar
did you put the headers in from the top or bottom?
Old May 2, 2005 | 06:20 AM
cb94ta's Avatar
I put both of them in from the top, they went in pretty easy I jacked the motor up a little on the passenger side and they went right in, I pulled the egr tube off of the intake to see if I can bolt up the headers without it in the way.
Old May 2, 2005 | 06:38 AM
BLinindoll's Avatar
Man, these Pacesetters seem to be "the thing to do" lately. Think I'm gonna have to give em a try.
Old May 2, 2005 | 09:36 AM
cb94ta's Avatar
The egr will not line up, what happens if I just don't hook it up? I'm waiting on block off plates, is it possible to drive with out the tube hooked up?
Old May 2, 2005 | 10:03 AM
nonojoe66's Avatar
i could be wrong but i think u need to at least block up the tubes or u will be sucking air into the intake and it wont run rite
Old May 2, 2005 | 10:06 AM
Mystic97Z's Avatar
just put the egr back on with a folded up tin soda can over the holes..worked for me until i got my plates..
Old May 2, 2005 | 11:15 AM
cb94ta's Avatar
Finally got the egr tube hooked up, don't know if I'm outhe woods yet because the tranny dipstick isn't wanting to go back in the hole, how much of an job is it to put on the offroad y pipe?
TitoPR221
May 26, 2015 12:20 AM
Russ95Z28
Apr 23, 2015 01:55 PM
transam_388
Mar 15, 2015 11:53 AM
cmyname1
Feb 19, 2015 08:38 PM
