fuel system pics
Old Mar 7, 2006 | 02:43 AM
blown383's Avatar
fuel system pics
Does anyone here have pictures of their fuel system? I'm looking to upgrade to stainless lines, boost referenced regulator, filter, etc... and need some ideas on plumbing so I can keep things looking neat underneath the hood.
-B
Old Mar 7, 2006 | 10:57 PM
blown383's Avatar
Re: fuel system pics
ttt for system pics!
-B
Old Mar 8, 2006 | 05:38 AM
Guest47904's Avatar
Guest
First pick the pump you want and figure out where you're gona install it. Then call the tech guys at Summit. When you find out what you "should" do, you'll get someone else to do it.
2 golden rules for installing a pump outside the tank that is the only pump in the system. It must be as close to the tank as possible and the tank should drain from the bottom to the pump.
Some use a helper pump located outside the tank which also has one in it. Some just upgrade the one inside the tank.
I chose to sump the tank and put only one on the outside and powered it up from the original voltage source.
One last thing, the stainless hose is a bitch to work with when cutting and terminating so get matched hose and couplings. Good advice from the folks at Summit goes a long way.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jul 4, 2005 05:00 PM
