Fuel System Lean
Old Mar 4, 2009 | 06:49 PM
Austin_78@msn.com's Avatar
Angry Fuel System Lean
Ok so my car has been throwing the lean code (DTC 55 and DTC 44)
I have....
-replaced fuel injectors to 26lb injectors
-replaced fuel pressure regulator
-replaced fuel pump
I have no idea what to do as of now! Any ideas?
Thank you.
Old Mar 4, 2009 | 07:37 PM
MikeGyver's Avatar
lol replace the fuel filter
Old Mar 4, 2009 | 10:10 PM
Are you running the 26# Accel injectors in your signature? They seem to cause a lot of problems, compared to other brands.
Have you checked your fuel pressure? Have you cleaned the MAF? Have you checked for a tear in the inlet elbow, or to see if the bottom edge of the elbow is not over the throttle body? What kind of HP is it making - 26# isn't much of an increase over stock.
Old Mar 5, 2009 | 04:00 PM
oh sorry lol i just changed my fuel filter as well.
Yes, accel. 26lb injectors
I dont have a MAF in my year.
Have not checked fuel pressure and yet to be dynoed..
My elbow is tore and i dont know if its totally sealed. would that cause it to throw the code? I kind of have my intake system patched up ghetto right now
And thank you for the imput
Old Mar 5, 2009 | 06:14 PM
transAMdriv3r's Avatar
I would get it on a scanner and see what the o2 sensors are reading and check the other sensors to see what else might be contributing. Could be a number of things.
speed density so maybe your map is faulty.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95maroboi
Jun 7, 2015 12:18 PM
Jul 4, 2005 05:00 PM
