Brand new OEM shortblock - want to change rods/pistons - machine work?
Old Mar 5, 2009 | 01:00 PM
LT1PoloGreenSS's Avatar
Do I need to get any machine work done by a shop if I want to change out the OEM rods/pistons for forged manley rods and diamond pistons? It is a brand new shortblock, never run. Just wondering..
Old Mar 5, 2009 | 01:36 PM
rskrause's Avatar
Moderator
The rotating assembly will need balancing. If there is not still a visible crosshatch on the cylinder walls, it will need a light hone. You might even get away with the same rings, but if it has been run at all use new one. If not, be sure the gaps are right and put them back in the same hole (assuming they fit the new pistons, you will need to pistons with the same size ring grooves) Be sure all bearings go back where they came from. The piston diameter needs to be checked for proper piston to bore clearance, if your new pistons are too small, you will be screwed, if too big it will need to be bored. I would get a 10 over piston and have it bored and honed to fit.
Rich
Old Mar 5, 2009 | 01:47 PM
BUBBA's Avatar
its a brand new short block.
Old Mar 5, 2009 | 01:51 PM
rskrause's Avatar
Moderator
If it was started for testing then it still needs a hone to get the new rings to seat, unless you can reuse the original rings with the new pistons and put them in the same holes.
Rich
Old Mar 5, 2009 | 02:07 PM
I'm not sure if GM ever started it way back when? do they usually assemble short blocks and start each and every one of them?
Old Mar 5, 2009 | 02:14 PM
BUBBA's Avatar
Just curious: is it a 4-bolt main? All replacement short blocks were 4-bolts.
Old Mar 5, 2009 | 06:38 PM
Stl94LT1's Avatar
I would sell or save the new stock short block, and build a used one.
Old Mar 5, 2009 | 06:39 PM
Stl94LT1's Avatar
How would you go about starting a short block?
Old Mar 5, 2009 | 07:24 PM
Kevin Blown 95 TA's Avatar
Get a midget to do it!
Honestly, you are putting some nice parts into it - I wouldn't go with the production tolerances, I would have it blueprinted.
Old Mar 5, 2009 | 07:38 PM
I'll just forget about changing the internals then. Going to put an AI 200CC heads/cam package on it though. Should be fine right ?
I was originally going to do a Forged 383 but the way i wanted it was going to be around $8500, and i am buying a $35000 C6 so i dont think its a good idea right now
Old Mar 5, 2009 | 07:48 PM
As long as the cam isn't too wild. You need better stuff to rev higher for a high duration cam and the static compression needs to match - tougher bearings and better rod bolts at least - maybe oil pump drive. See where that cam makes it's power, then see if you are alright with your components that you have.
alliance12364
Mar 6, 2015 04:39 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Collector Car
Jan 5, 2015 10:58 AM
Catmaigne
Dec 25, 2014 12:16 PM
heavenly_six
Dec 10, 2014 12:23 AM
