is this fuel setup gd enough to run le2 package
i currently have 24lb svo injectors and 255 lph fuel pump and was wondering if i will be running too lean. the car is tuned for 32s but is was running like crap so we switched in the 24s and it seemed to run alot better.
Re: is this fuel setup gd enough to run le2 package
Have you had your computer tuned yet? If not that is why it ran like crap with the 32lb injectors. The pcm needs to know what injector it has to have the right pulse. If you put 32 in place of 24. There going to open and close the same as the 24 but with more fuel.
Your 32 will work fine after a tune...the 24 might be maxed out,but it depends on your total setup..
F'n1996Z28SS
Aug 23, 2023 11:19 PM
