Porting 58MM TB
Porting 58MM TB
What is the most you can port your stock intake throttle body to, is it possible to go to 58 with a stock and I intend to port the intake to 58 as well because I think theres some untapped power in there!
Re: Porting 58MM TB
How much power are you pushing? Kinda doubtful you will find a big gain from it unless you are pretty heavily modded (heads / cam, full exhaust). Just imho though.
I run an AS&M 52mm TB on a healthy set of ported heads, mid sized cam, full exhaust with MAC headers. I did feel that a 48mm might be costing me a bit, but doubt I'll ever run so radical for a 58mm.
I dont know about cutting the whole thing out yet thats a little steep, but i am interested in the 53-58, ive got LT's straight pipes, 3in cai but im sure more air is more power, few months CC306 and 1.6RR
I looked at the Monoblades, man I kinda like that idea, would there be anything to watch out for?
http://web.camaross.com/forums/showt...=throttle+body <--good one
http://web.camaross.com/forums/showt...=throttle+body <-- ok one
http://web.camaross.com/forums/showt...=throttle+body <---good one
http://web.camaross.com/forums/showt...=throttle+body <--ok one
Those go back about a year and a half. Read all those and if you still have unanswered questions then try to be specific and either I, or hopefully someone who knows more than I will be able to answer them.
Hope that helps and good luck.
It isn't that I don't like having plenty of room to breath (within reason) it is just that TB are usually pretty expensive and that money, usually, can be spent better elsewhere.
Those links will give you a wealth of information, especially watch for posts by some of the boards prominant members, Fred (Injuneer), Brent (LT1 Tech Moderator), Ken Mook, and others that gave very well thought out and lengthly responses to this same question over the past 18 months or so.
I sincerely hope you'll read them and make and *informed* decision.
Here's what happens to a stock tb when you get it out past 53mm. In the next few pics you'll see a 2.11"(53.4mm) bore.
This picture shows how it breaks out around the throttle shaft boss on the spring side.
In this picture you see some square looking breakouts in the top of the bore. This area breaks out well before you reack 52mm, which makes me wonder what the bored out 52mm throttle bodies look like when finished. Also the bolt holes from the top cover plate break out well before 52mm.
I make inserts for the throttle bodies that press in to the bore and the final product flows the same amount of air as a 52mm and is only at 2"(50.8mm) It flows 740cfm @1.5"Hg and looks like this when finished.
My next task is to make a 58mm version just to see what happens. But to do this I will have to bore the throttle body out with a mill rather than on my lathe so I can control the offset of the bore inward to reduce the break out on the throttle shaft bosses on the outboard side.
