fuel pump replacement (trap door)
Old Aug 7, 2004 | 02:10 AM
CamaroSS30thAnn's Avatar
so i finally decided when i do my fuel pump im using teh trap door method b/c im lazy and i have to do it myself...i just need to talk my dad into it ...
anyway i havea cutoff tool but its one that use teh bigger blades.....can i just make a few cut and sheet metal clippers....also so i dont create alot of sparks? anything else i could use?
how would i go about sealing teh hole after im all done with it?
any suggestions or usefull info i can use pleae tell me
whos with and against thetrap door method....
thanks
Old Aug 7, 2004 | 03:46 AM
RamAir95TA's Avatar
Re: fuel pump replacement (trap door)
thanks
Here's the guide I made for the trapdoor method. Tin snips will also work.
http://www.worldisround.com/articles/12533/index.html
I used a thin piece of aluminum and very short sheet metal screws and RTV to cover the hole. Here's a picture of the install I did on a friends 96 Z28:
http://www.ramair95ta.com/tech/fp2.JPG
http://www.ramair95ta.com/tech/fp10.JPG
Old Aug 7, 2004 | 07:43 AM
N2OMARO's Avatar
I used a chris alston fuel door on my car. I just lined it with thin weather stripping no smell at all. makes for a ten minute fuel pump change.
Old Aug 7, 2004 | 08:01 AM
I would like to see this door. Got pics or a link to the product?
Old Aug 7, 2004 | 08:20 AM
ledfootz28's Avatar
i would also like to see a pic of that chris alton door.im sure my fuel pump will be going any day now
Old Aug 7, 2004 | 09:13 AM
N2OMARO's Avatar
Here is a link with a pic of the door I used. It is the larger one obviously. Im out of town at the moment but I will shoot some pics of it installed on monday.
They call it access door. I will get the dimensions of the door if you want them... I have to find my catalog first I guess
http://www.cachassisworks.com/accessories.htm
Old Aug 7, 2004 | 03:43 PM
yes show me the door to ....now i need to talk my dad into this ...he wont help me the bastard ....which means i cant use his tools.....this sux....
Old Aug 7, 2004 | 03:49 PM
Lyle A's Avatar
That's exactly what I did but I had to cut a little more over the disconnects. How did you get to them with out doing that?
Old Aug 7, 2004 | 04:25 PM
RamAir95TA's Avatar
Small hands? It was pretty easy. A very long needle-nose pliers and a screwdriver, and all of them came off very easily.
Old Aug 7, 2004 | 08:36 PM
hey so are the walbro/racetronix and granetellis teh same thing?,,
Old Aug 8, 2004 | 07:37 PM
^anybody.....
BTW i replaced teh pump ...it runs great ,,,i did notice when revved at high rpms it would runa little rich .....
one question....b4 i patch up teh hole what i did was use a few zip ties to hold the bucket together while teh glue settled.....im nto going to do this but i was wonderign how long will the zipties last in gas..lol....just a wonder ...
also any suggestive or creative ways to patch up the hole....i was gonan use RTV sealant some sheet metal and screws
Old Aug 8, 2004 | 10:34 PM
Lyle A's Avatar
Go by Ramair's link below. It is a solid method. Just use real short sheet metal screws and RTV. That's good enough. 10 screws will do it. Round your edges and corners for a stronger cover.
RiverMutant96
Jan 30, 2015 09:21 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
