Fuel pump repair kits?
Old Oct 19, 2023 | 09:35 PM
48builder's Avatar
I'm getting ready to start my 1948 Z28. A little explanation on that. I'm building a '48 Chevy street rod. I bought a wrecked '95 Z28 and took the entire drive train, including the rear suspension, tranny, wiring harness, etc. and put it into the '48 body. I did have to use a '87 Grand Prix front end because of the width. I had a custom aluminum gas tank made to fit the stock fuel pump. I'm keeping all the vapor canister, etc.
My fuel pump needs the 2 hoses other than the flexible one. They are rotted. Anybody know where I can get them, or barring that what is the best solution for buying a new complete pump?
Thanks for any help.
Walt
Old Oct 20, 2023 | 04:45 AM
chevykid's Avatar
Re: Fuel pump repair kits?
here is a replacement fuel pump, i put one in my camaro back in 2019 and still running strong
https://a.co/d/hmyLm9u
Old Oct 20, 2023 | 11:33 AM
I asked the guy who bought my car where he got the black plastic flex lines. They came with a pump he bought from Racetronix, but he thinks they sell the lines separately.
https://www.camaroz28.com/forums/gen...2/#post7017145
Old Oct 20, 2023 | 07:11 PM
48builder's Avatar
Thanks for the info, guys. A friend who builds street rods for a living stopped by today and recommended I just buy the new pump since mine has been sitting around in my garage for 20 years.
Old Oct 21, 2023 | 07:53 AM
Sounds like a better solution.
Old Oct 28, 2023 | 06:40 PM
48builder's Avatar
This may be a dumb question, but I'm new at fuel injection systems. The new pump flex line has what looks like some type of filler (the white part) that I think I have to take out in order for it to connect to the quick-connect fitting on the original pump. Can someone confirm that? And the new screen looks like it just pushes on, right?
Old Oct 28, 2023 | 08:15 PM
You mean the grayish plastic part, with the square button on each side of the connector? That looks like the “snap” that slips over the raised metal rib on the line it connects to, and keeps the connection tight. Squeezing the button would release it.
Old Oct 29, 2023 | 03:19 PM
48builder's Avatar
I'm a dumbass. You are correct. The old quick release thingie was till on the pipe. I took it off and the new flex pipe slipped right on. Thank you
Old Nov 7, 2023 | 06:35 PM
48builder's Avatar
Got the new carter pump Chevykid recommended and the tank is installed in the car. Had to cut one of my steel lines and remove it in order to get another union tight. All I need to do now is get the steering column in and finish the engine harness and then I can try to start it. Thanks for the help.
Walt
elis94camaro
Feb 15, 2010 09:41 AM
MEAN LT1
May 30, 2007 09:45 AM
weinerschizel
Aug 15, 2005 10:25 AM
zennx
Apr 2, 2004 11:31 PM
Jesse_Boyer
Jul 7, 2003 08:57 PM
