fuel pump question
Old May 24, 2011 | 07:58 AM
dennis5374's Avatar
fuel pump question
How much hp can the airtek fuel pump support brand new out of the box? I'm buying a set of le3 heads, 1.6 rr, cc306 cam, 11.5 to 1 , 355 shortblock. Have all boltons as well with 42#, injectors.
Old May 24, 2011 | 08:01 AM
RamAir95TA's Avatar
Re: fuel pump question
What's it rated at in LPH?
Your typical Walbro 255 is usually good for MOST N/A applications. I have a Walbro 255 on my car and have no pressure drop at WOT with 42# injectors. Your setup is milder so I wouldn't be concerned as long as it has the same flow characteristics as the popular Walbro 255.
Old May 24, 2011 | 05:21 PM
Do you possibly mean "Airtex"?
The Airtex online catalog has very little info about the pump (#E3908), at least if you put 93 Camaro 5.7L into the parts lookup.
http://www.showmetheparts.com/airtex/
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
