Fuel Pump Problem?
Old Apr 26, 2004 | 03:43 PM
LT1 PWRD's Avatar
Fuel Pump Problem?
OK, here it goes, my 95 z28 died the other day and wouldn't restart.
I've since established that I've got spark and that I can't hear the fuel pump turn on for those 3 seconds when turning the key.
I can hear some relays click on and off under the dash. I haven't tested the relay yet.
The SES light does come on too.
Here's my questions,
Which fuse is it for the fuel pump? located inside the car with the other fuses right?
How easy is it to change the pump when cutting inside the trunk area and making an access panel? Some people have used a dremel tool to cut it out....Isn't that a bit risky????!
Is it hard to reach and disconnect the fuel lines from that access panel?
Thanks, can't wait to get my car on the road again.
Old Apr 26, 2004 | 03:53 PM
HBHRacing's Avatar
you can follow this link and see how the elctrical system for the pump works and how to test it as well as everything else that will make the car not start
http://mainstreamtopics.com/forum/in...p?showtopic=78
Old Apr 26, 2004 | 04:32 PM
LT1 PWRD's Avatar
thanks for that link. I'll test the electrical before cutting the panel in the back.
Now, which way is best to cut the sheet metal out?
Old Apr 27, 2004 | 05:27 AM
slopokrodrigez's Avatar
The best way to cut the panel is to very carefully drill a starter hole without drilling too deep and nicking wires. Then use a nibbler to make the rest of the hole.
BTW, it's a good possibility what you hear as far as relays is either the fuel pump relay or the theft deterrent relay. You should scan the codes to see what is going on.
Old Apr 27, 2004 | 10:07 AM
Red96Lt1's Avatar
The acess panel is not too hard. I used a dremel and was just very careful.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
