Fuel Pump or Opti?
Old Jul 20, 2005 | 09:03 PM
riaf28's Avatar
Fuel Pump or Opti?
I've changed out my spark plugs, wires, and changed my fuel filter but I still have hesitation below 1500RPM and it has to crank a while befoe it starts up. I'm wondering if there is a definite way to know if the Opti is gone or if I need a new fuel pump. Am I just stuck with a 50/50 chance on either one?
BTW, the car is a 1993 Z28 A4.
Old Jul 20, 2005 | 10:29 PM
Re: Fuel Pump or Opti?
Attach a fuel pressure test gauge to the fuel rail to rule out fuel pump problems.
Old Jul 20, 2005 | 10:40 PM
Formula_driva's Avatar
I have the EXACT same problem as you..
Old Jul 20, 2005 | 10:49 PM
droptop z's Avatar
hey before you go and order parts, take a look at your ignition coil wire. i had the same problem and when i tried to take it of it just crumbled to dust at the boot.(white powder) good luck!
Old Jul 21, 2005 | 01:26 AM
'94 Red Dragon's Avatar
Holy ****
I have a the same problem with my '94 TA. Its get a very small constant miss and has the crank a while to start ( Fuel pump is good )
PLEASE HELP
Old Jul 21, 2005 | 08:46 AM
riaf28's Avatar
I'll check the coil wire over the weekend and see if that is my problem.
Old Jul 21, 2005 | 03:18 PM
I however have not checked my fuel pump....
one of us needs to solve this!
grabbem88
Apr 16, 2015 06:57 PM
grabbem88
Mar 18, 2015 01:25 PM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
