Fuel pump install pics, through the hatch!
Old Mar 16, 2004 | 10:20 AM
  #16
magius231's Avatar
the passengers side panel has 3 quick release trim tabs that you turn to unlock and it all comes out. The drivers side one just pulls straight up and out...beware of speaker connections if you have them back there, you don't want to pull them out.
Old Mar 16, 2004 | 10:51 AM
  #17
GREGG 97Z's Avatar
Nice job, I did almost the exact same thing last fall when I installed my Walbro. You can buy 2 foot square pieces of 24 gauge sheet metal at Home Depot, it's pretty thick and very close the the thickness of the sheet metal used in that spot. I did that and used stubby point self tapping screws, they are shorter than the normal pointy 5/16 screws and have a flat tip to be sure I didnt hit the fuel lines. RTV'd it down too, didnt paint it though, mines silver anyway
Old Mar 16, 2004 | 11:08 AM
  #18
RealQuick's Avatar
The pieces I speak of are the ones with the speakers in them next to the back seats. Are those the ones you are referring to? Thanks for the help.
Old Mar 16, 2004 | 11:53 AM
  #19
DR.ZED's Avatar
Re: Fuel pump install pics, through the hatch!
Who loves browsable directories? I know I do...
Old Mar 16, 2004 | 12:46 PM
  #20
Toast's Avatar
Those back seat panels come out fairly easily. The only tricky part is that you have to pull out the center section of the hook that is used to hang coat etc. and then that hook will come out. The rest of the panel just pulls out. There might be a screw or two towards the front where it meets the panel that runs next to the door.
Old Mar 16, 2004 | 12:54 PM
  #21
RealQuick's Avatar
I'll take a look. Thanks.
Old Mar 16, 2004 | 03:38 PM
  #22
RamAir95TA's Avatar
You don't need to remove those panels, just the ones that are immediately ajacent to them that house the speakers in the far rear. The one that conceals the spare tire and the other directly across from it. That's all.
Old Mar 16, 2004 | 03:41 PM
  #23
TransAm219's Avatar
here is a good one too
http://www.ramair95ta.com/tech/FP.JPG
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
