Fuel pump going out??? New pump options?
Old Jul 19, 2009 | 09:47 PM
96SSIndeed's Avatar
We are begining to think my fuel pump is going out. I checked the pressure today, at shrader valve: key on 47psi, car running 40psi. Which is within range but the car still feels as if its not getting fuel. We changed the fuel filter before the pressure test and took it for a ride, felt better then got worse. Is it possible the pump isn't producing enough pressure while driving?
My friend thinks that maybe the filter was bad enough the pump was getting hot and working to hard which caused it to finally start acting up. The reason he thinks this is because the car would sometimes run good in the mornings after not driving it the day before, then after about 30 min of driving, it would start acting up and not run right the rest of the day. Could this also be why the car seems to have gotten slower over the past couple months? Any help or suggestions would be appreciated.
I'm going to trap door the fuel pump so i'm not worried about changing it. Also are there any aftermarket fuel pumps i can get that drop rieht in the tank? I looked at the racetronix walboro, but it looks like it requires extra wiring and stuff.
Thanks Chris
Old Jul 19, 2009 | 09:54 PM
mad95z's Avatar
Those pressures look good
Old Jul 19, 2009 | 10:06 PM
96SSIndeed's Avatar
I'm not sure if its keeping up when the car is being driven though. I don't have a gauge in the car, so i'm not sure how to check it while driving
Alos anyone ever use this, http://www.summitracing.com/parts/GR...2/?image=large.
Old Jul 19, 2009 | 10:34 PM
mad95z's Avatar
You need a longer hose, then tape the gauge to the windsheild.
Dont do this in rush hour traffic though, LOL
Old Jul 19, 2009 | 10:44 PM
96SSIndeed's Avatar
lol. i thought about it honestly
Old Jul 20, 2009 | 10:43 PM
ssbowtie1's Avatar
Why not test the fuel pressure when the car starts acting up?
Your reasoning makes sense, but doesn't rule out other components that may cause your problem.
Anyways, as for a fuel pump replacement you want to go here:
http://www.racetronix.com/RX-FLT1-FPKG-2.html
Old Jul 21, 2009 | 09:36 AM
raroz28's Avatar
Racetronix is too expensive. There is a walbro dealer on ebay who has some great deals. Brand new walbro, with the install kit, with a 1 year warranty. Same as racetronix but $50 less.
Old Jul 23, 2009 | 06:03 PM
96SSIndeed's Avatar
Is this the kit everyone uses?
http://www.racetronix.biz/customkiti...c=RFPK-003&eq=
Old Jul 23, 2009 | 07:27 PM
Cobra2k7's Avatar
How long is the hose for the guage, mines JUST long enough to shut the hood and tape it to the window.
Only real way to know for sure if thats the problem is to check the pressure while driving/ WOT.
When mine went out, the pressure at idle was fine. It wouldnt hold pressure when the key was off, it would drop right away. At WOT the pressure would drop to 25 psi.
Old Jul 23, 2009 | 07:33 PM
96SSIndeed's Avatar
i actually thought of doing this, but i just ordered a fuel pump so i'm just going to change it. its probably the factory one any way. i'll need it when my engine gets done anyway
Old Jul 24, 2009 | 07:34 PM
ssbowtie1's Avatar
Originally Posted by 96SSIndeed
You don't need the fuel pump hot wire kit.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Jul 4, 2005 05:00 PM
