Fuel pump
Old Apr 27, 2005 | 10:11 AM
kadoi's Avatar
Fuel pump
My fuel pump died in my 95 trans am. What do you guys think a price should be on one of these because i have called around and brand new they are all 176. Would it be safe to go with a used one, or what have you guys typically done when your fuel pumps have failed as far as upgrading to a better one,and my car is one of the split years on the emissions system and has OBD-I with the OBD-II connector. Can i just jump the computer like the origional OBD-I or do i have to take it to the dealer since the OBD-II scanners will not work.
Any help would be greatly appreciated,
Cory
Old Apr 27, 2005 | 10:38 AM
Red96Lt1's Avatar
Re: Fuel pump
Racetronix kit. Better than stock for $150.
As for replacement, make a trap door inside the car so you don't have to drop the tank. Do a search for instructions.
Old Apr 28, 2005 | 05:36 AM
slopokrodrigez's Avatar
Re: Fuel pump
Why do you need to do anything with the DLC?
Old Apr 28, 2005 | 05:43 AM
Racetronix's Avatar
Re: Fuel pump
Cory
We have stock-type and low-pressure replacements if you do not require the 255L/Hr HP version. You can save yourself a bit of money. These are special order but we can ship the same or next business day. You can place a special order through Thunder Racing.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
