fuel pressure setting???
Old Apr 30, 2004 | 07:37 PM
GpMike24's Avatar
where should i set my fuel pressure regulator w/ 30# injectors
Old Apr 30, 2004 | 07:39 PM
GreenDemon's Avatar
I would set it around 40 and then take it on some runs with a scanner to adjust the a/f ratio. Even if you don't tune, the computer will correct most of it to where it wants anyway.
Old Apr 30, 2004 | 08:50 PM
96capricemgr's Avatar
Ask Bryan what pressure he tuned it for, if he was using 45lbs. as the basis for the tune and you set it to 40lbs. it won't run right and would be very lean up top. Especially with that MAF those trick the pcm into running lean as is, make sure Bryan knows about that, or better yet put the stocker back on.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
Nostang 96z
Sep 10, 2002 08:54 PM
