Fuel pressure regulator Question?????
Old Apr 2, 2003 | 11:12 AM
  #16
97firechicken's Avatar
I borrowed this from Shoebox, but is it that Fuel shrader Valve?
http://csce.uark.edu/~jgbertr/rb/intake_rear.jpg
Old Apr 2, 2003 | 11:16 AM
  #17
norcalstreet's Avatar
http://members.aol.com/Fredrick518/Photos/bkofint.jpg
Here's another picture. The shoebox one is what you're looking for. This picture seems to have had a gauge adapter put on it.
Old Apr 2, 2003 | 11:17 AM
  #18
Mikey97Z's Avatar
Originally posted by norcalstreet
The 94+ PCM's monitor the fuel pressure. When the fuel pressure is changed the PCM adjusts the fuel injectors to account for it.
I'm pretty sure that the PCM does NOT monitor the fuel pressure.
That's why I had to install a fuel pressure gauge on my dashboard. The PCM doesn't have that info. It makes corrections by monitoring the 02 sensors and adjusting the pulsewidth of the injectors.
Old Apr 2, 2003 | 11:20 AM
  #19
That's more or less what I was driving at. Through the O2 sensors it makes the corrections. One way or another the AFPR will not work on a 94+.
Old Apr 2, 2003 | 02:23 PM
  #20
Ok now that im starting to get confused, what should i do, i have a 97 Trans Am with a OBDI custom program that has the emissions turned off. Should i get an adjustable one? or go back with just a replacement?
Old Apr 2, 2003 | 02:54 PM
  #21
Price them out. If the adjustable one is the same price as a stock one get an adjustable one. Whatever the case you can always have it adjusted to stock fuel pressure.
Old Apr 2, 2003 | 03:08 PM
  #22
Ok my next question is if i get an adjustable one, what should i set it at? And will it interfere with my PCM?
Old Apr 2, 2003 | 03:14 PM
  #23
Set it to 38 PSI. That should be about right.
DirtyDaveW
Dec 1, 2016 05:37 PM
nophix
Nov 30, 2014 10:26 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
