Fuel Pressure Regulator
Old Oct 24, 2006 | 04:22 PM
LT1_King's Avatar
my car idles pretty rough and when i get on it to about 3500-4000 rpms it starts throwing out black smoke through the exhaust and doesn't want to accelarate any more. could this be a lack of fuel maybe it could be running lean? could this be the fule pressure regulator or if i changed the fuel filter could that help? it's a 94Z A4.
Old Oct 24, 2006 | 04:25 PM
Black smoke would more likely indicate rich-not lean. You might need to check your pressure with a test gauge. You can also remove the vacuum line to the regulator and check it for the presence or smell of fuel. If it is leaking into the vacuum line, that can cause a rich condition. Bad O2s can cause air/fuel problems, too (as can a number of other things).
Old Oct 24, 2006 | 04:27 PM
BUBBA's Avatar
Black smoke probably indicating unburnt fuel, i.e, you are probably running too rich rather than too lean. Perhaps your 02 is boogered.JMHO
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
