fuel pressure regulator?
Old Apr 24, 2004 | 08:39 PM
97WRAITH's Avatar
Do I need one when switch from stock injectors to 30lb svo's?
Thanks!
Rob.
Old Apr 26, 2004 | 12:37 AM
You need the stock FPR, you don't need an adjustable. Just tell your programmer what injectors you are using, and "stock fuel pressure", and they will set the injector constants as required.
Old Apr 26, 2004 | 04:13 PM
97WRAITH's Avatar
Thanks Fred!
Old Apr 26, 2004 | 04:18 PM
OBE1 95Z28's Avatar
I agree with Fred that the computer program can compensate for the larger injectors but since you have an aftermarket cam and ported heads, an adjustable FPR gives you more options. My heads and cam were running a bit lean at idle with the stock fuel pressure but WOT looked great for A/F ratio. I was able to bump up the fuel pressure to fix the lean idle (was throwing a code). I'm sure this could also be corrected via programming but since I'm not doing my own programming it's a pain to keep going back to your programming source.
Old May 17, 2004 | 08:47 PM
Hawk350's Avatar
I had my pcm programmed fro 32lb injectors and a 255lph fuel pump....I didnt install the new fuel pump and now my car is running wayyyyy rich and fowling plugs.....should I get a fuel pressure regulator?
Old May 17, 2004 | 09:12 PM
96capricemgr's Avatar
No get it reprogrammed for what you do have that is the only right way to do it since it is more than just the flow rtating changed for injectors.
Old May 17, 2004 | 09:20 PM
Hawk350's Avatar
so what you are saying is that when it was programmed, it was done incorrectly? If I installed the 255lph, would my problem go away?
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
