Fuel Pressure Regulator
Old Feb 19, 2004 | 10:02 PM
Kataklysm's Avatar
In need of a new fuel pressure regulator, just gonna go with an adjustable one, not running anything high end just gonna need the normal fuel pressure....which brand should I go with?
Also I need to run new fuel lines, should I just get them from GM?
Old Feb 19, 2004 | 10:24 PM
OBE1 95Z28's Avatar
I've been running a TPIS AFPR for the last 50K miles with no problems. My buddy ran an Aeromotive and it failed right away.
Fuel lines are a GM part only unless you're looking to do a custom job.
Old Feb 19, 2004 | 10:27 PM
Kataklysm's Avatar
Whered you get the TPIS? How much? Thanks for the info I really apriciate it, the beast is down and hurt.
Old Feb 19, 2004 | 10:37 PM
Robs97Z28's Avatar
I also have tpis and have had for about 40,000. No troubles. They have two ways to go. http://www.tpis.com/ 100-023 Regulator Hat Kit, all LT1........$49.95 or 100-017 Adjustable Fuel Pressure Regulator, 94-97 F Body & Impala/Caprice/Roadmaster........$119.50
Old Feb 20, 2004 | 06:40 AM
IDOXLR8's Avatar
I would go with a stocker. No need for an AFPR.
Old Feb 20, 2004 | 07:37 PM
revtime's Avatar
I went with a holley.
Very nice piece, if your going with an AFPR I reccomend it.
Its pretty, too bad its stuck back there where no one can see it......
Old Feb 25, 2004 | 09:25 AM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
other than a damaged stock unit is there any reasons or gains to change it out and raise or lower the pressure??
david
Old Feb 25, 2004 | 07:32 PM
revtime's Avatar
not on a stock car...the PCM will adjust.
I had a bad stock one so I went with the holley.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
