fuel pressure regulator
I have 30 lb injectors and 255 fuel pump with stock fuel pressure regulator. Do I need to get an aftermarket one? I can hear fuel pushing hard through injectors when I turn the key. Seems that board has nothing on fuel pressure regulators
Tomas
Tomas
I noticed when I installed an aftermarket pump (Paxton Kamikaze) that my fuel pressure went up. I'm not sure why. But I installed an aftermarket pressure regulator so I could adjust it back down to stock pressure. You may want to check your pressure if you feel it's too high.
Dave
Dave
Originally posted by 95 WHITE TRANS
I think even though you could adjust your fuel pressure with an after market regulator,it stays like that for a while, then the pcm reajusts it.
Originally posted by tanker
Let me know terran2k if the fuel pressure regulator added any performance to your car? Which brad did you get? Notice any difference.
Dave
charchri4
Apr 14, 2015 06:40 PM
