Fuel Pressure Reg and PSI Question?
Old Sep 14, 2007 | 12:37 PM
DAVE00's Avatar
Guys/Gals,
I have a 383 setup and am replacing the fule rail and regulator (crack in the rail). What regulator and PSI would you recc for this setup? I am thinking of the Holley but it only goes to 60PSI and I am not sure if this will suffice. I am currently running 24lb injectors and need some help ASAP???
Old Sep 14, 2007 | 12:49 PM
96capricemgr's Avatar
Get the right injectors and leave the regulator STOCK.
By right injectors I mean something like 30lbs SVOs or larger.
Old Sep 14, 2007 | 09:21 PM
Why do you feel you need a fuel pressure higher than 60psi? Why do you feel you need a fuel pressure anything other than stock (43.5psi)? What kind of flywheel HP do you expect to make? That will determine the injector size, and in turn may define the fuel pressure requirements if injector duty cycle is an issue.
DirtyDaveW
Dec 1, 2016 05:37 PM
Alex Barnes
Jan 24, 2015 10:21 PM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
