Fuel pressure question
Car is a 96 Z. It does not run right now, if you prime the fuel system a few times it will run for a second then shut off. Put a fuel pressure gauge on it and under prime and cranking only got 3psi (WAY LOW I know). My dad told me that before I go and buy a Racetronix that I should check the relay and I was about to untill it started raining. If that was bad I would assume the fuel pressure would be at zero right???
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
