Fuel pressure only 36psi at idle
Old Oct 29, 2006 | 08:29 PM
mrmint69's Avatar
I put a gauge on the windshield and got 40 psi when i first started the car. As soon as i drove it it would go to 36 and stay there until i accelerated. It will go to the mid 40's once i get on it. Is this normal and should i check something else. I have an fmu for the supercharger but no inline pump hooked up.
Old Oct 29, 2006 | 08:31 PM
MeanGreen97Z's Avatar
I'm dealing with a weak fuel pump myself. 36psi isnt terrible. Mid 40s when you get the RPMs up is right where you want it. I'd say you are good to go with that. Pump might be a tad weak but I see no issues. You having an issue with the car?
Old Oct 29, 2006 | 09:16 PM
mrmint69's Avatar
I have been dealing with a fuel pressure loss (0 for split second) at wot and over 5000 rpm. I took the inline pump out of the car and ran it. The psi with the inline pump was constant at 39 unless under throttle. Now it is 36 psi. I don't know what to check now. Fmu, intank pump & regulator?
Old Oct 29, 2006 | 09:19 PM
Definately weird. Did you unplug the vacuum hose from the regulator when you tried the fuel pressure at idle?
Old Oct 29, 2006 | 09:53 PM
mrmint69's Avatar
I did and the pressure went up about 6 to 8 with it off and plugged at the regulator.
Old Oct 29, 2006 | 09:55 PM
Well the regulator is working. You might have a weak pump or a wiring issue. Possible corrosion or something to that effect.
Old Oct 29, 2006 | 10:07 PM
96capricemgr's Avatar
Might help to understand what the regulator does. It actually maintains one fuel pressure all the time but in reference to manifold vacuum and a gauge references off atmosphereic pressure. If the gauge references off manifold vacuum/boost the fuel pressure should never change. If it were not setup like this the high vacuum at idle would "suck" extra fuel from the injectors making them act larger. Under boost the pressure in the manifold would resist the fuel pressure and it would reduce the amount of fuel delivered.
Old Oct 30, 2006 | 09:48 AM
BUBBA's Avatar
Sounds about right to me----should read around 43-46 with the vacuum hose off the regulator (simulating WOT at idle) and around 8 less with the hose on. I.e. if you're seeing 36 with the hose on that=about 44 with the hose off. Or am I wrong? JMHO
Old Oct 30, 2006 | 10:13 AM
Fuel pressure seems normal... 36psi at idle, jumps 6 to 8 psi (= 42-44psi) with the vacuum line off. The question is how does it hold up over 5,000rpm and the normal figures for acceptable fuel pressure at WOT will not apply, since he has an S/C and an FMU which raises the fuel pressure under boost.
He has another thread on the problem:
http://camaross.com/forums/showthread.php?t=480106
Old Oct 30, 2006 | 10:15 AM
Another thought... the fuel pressure drops to "0". Have you checked you gauge/sending unit? Have you watched your fuel injector pulse width when the pressure drops to "0"? Does the pulse width drop to "0" as well?
DirtyDaveW
Dec 1, 2016 05:37 PM
Gtpguy
Jan 26, 2015 04:50 PM
Alex Barnes
Jan 24, 2015 10:21 PM
F(ast)-body
Feb 26, 2003 09:05 AM
