Fuel pressure jumping around?
Old Jan 13, 2004 | 07:45 PM
Billet ss's Avatar
My pressure dances around from 38psi-44psi when running,and my gauge is making noise.The pressure holds when you cut the car off,and doesn't fall at wot?
Old Jan 13, 2004 | 07:55 PM
MentalCaseOne's Avatar
Is it your stock fuel pressure regulator?? if it is then it should be fine.
Mine goes from 36psi to 46psi depending on engine vacum.
with the engine off it maxes out at 40psi.
About your gage making noise.... could you be more specific? what kind of noise? could it be fuel injector noise??
Marvin
Old Jan 13, 2004 | 08:02 PM
Billet ss's Avatar
I have a adjustable reg,The noise is a ticking sound coming from the guage.I know it souldn't move around at idle?
Old Jan 13, 2004 | 08:11 PM
Mine does move at idle but only about .5psi. if it goes from 36 to 44psi then something is wrong... do you have a vacum leak ?
I am almost sure the ticking sound is fuel injector noise.. they click and the sound is transmited through the gasoline. It should not be loud at all.... barely perceptible though.
Do you have a big cam with a lopey idle and low vacum? that may be the reason why your fuel pressure is so unstable... I am assuming you have a vacum line connected to your fuel pressure regulator right?
Marvin
Old Jan 13, 2004 | 09:14 PM
'94 Bad A Z28's Avatar
Re: Fuel pressure jumping around?
Do you mean when you are crusing around town it is at 38psi, and then when you press the gas it moves up to 44psi, and then settles back down to 38psi again? If so that is normal, if not please describe it a little better.
Old Jan 13, 2004 | 09:22 PM
Billet ss's Avatar
Its bouncing around all the time,at idle,when moving and at wot.The pressure is holding its just boucing around.
Old Jan 14, 2004 | 12:15 AM
I just tested my vehicle for that clicking sound that you were talking about. With the engine at idle I grabbed the fuel line before the fuel rails and sure enough I can clearly feel the Fuel injector clicking vibrations on the fuel line....I think your gage is just amplifying the pulses to an audible level.
One more thing about your fuel pressure... the regulator controls the pressure by using engine vacum. anytime the vacum drops below a threshold level the fuel pressure increases. Unless you completely disconect your engine vacum to your fuel pressure regulator you will see those fluctuations under normal driving.
Why dont you try this test, unplug the vacum line... plug it with a small screw or something and drive around for a few minutes, your fuel pressure should be high but steady... if it still has those wild swings you may have a fuel delivery problem... either your pump is on the way out or there is a loose powerline conection to your fuel pump somewhere.
Marvin
Old Jan 14, 2004 | 01:36 AM
InjectedSS's Avatar
Sounds like some kinda loose connection to your guage if it's just bouncing around like you say!
Old Jan 14, 2004 | 05:32 AM
slopokrodrigez's Avatar
Do you have a mechanical gage in the cockpit??????????
Old Jan 14, 2004 | 07:16 AM
Billet ss's Avatar
I have a auto meter fuel guage in the pod,I'll check the vacumm line today.
Old Jan 15, 2004 | 02:41 PM
Billet ss's Avatar
I checked the vacumm line no leaks, reg working properly I dont know cant seem to find anything wrong?
Old Jan 15, 2004 | 02:51 PM
Exactly what kind of fuel pressure gauge do you have..... mechanical or electornic? I see its an AutoMeter, so that tells me it isn't the typical problems from some of the other brand digital gauges. If it is electronic, which model? How old is it? Exactly where is the pressure sensor located?
Old Jan 15, 2004 | 06:42 PM
Billet ss's Avatar
Its a mechanical guage,3 month old and I tapped into the vavle on the fuel rail.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
