Fuel pressure = zero psi?
Old Aug 3, 2003 | 12:59 PM
PROJEKT Z28's Avatar
Exclamation Fuel pressure = zero psi?
Started my car last night, and it ran weak until it died (like it ran out of gas). Checked the fuel pressure today and it is 0 psi- I expected a least some fuel pressure-
Just posting this as a sanity check- If the fuel pump died, and I tried to start it a few times, I assume that would deplete the fuel pressure, hence the 0 psi?
Am I missing anything, or is it time to order a walbro?
Old Aug 3, 2003 | 01:11 PM
Josh-'04 GTO's Avatar
You're not insane....0 psi=dead car. When you turn the key on, can you hear the fuel pump prime? There might be fuse for that, I'd check that before I bought another pump for nothing!
Old Aug 3, 2003 | 01:30 PM
Don't forget to check/replace your filter.
Old Aug 3, 2003 | 01:46 PM
funina91ss's Avatar
Yes check the simple stuff first. fuses, relays, filter power at the pump harness. its under the car where the back of the seat is on the lt side..
Old Aug 3, 2003 | 02:25 PM
When I turn the key to the ON position, I can hear the fuel pump prime: click on - 2 seconds - click off.
This indicates to me that there aren't electrical problems as far as fuses and relays go- It suggests mechanical failure - the pump.
Right?
Old Aug 3, 2003 | 02:37 PM
funina91ss's Avatar
Right?
Take the fuel filter off and then turn the key forward and see if any fuel comes out the line.
Old Aug 4, 2003 | 12:45 AM
How did you measure the fuel pressure? Did the gauge you used have a pin in it to depress the core on the Schrader valve? If you prime the pump and depress the core of the Schrader, does fuel squirt out?
Old Aug 4, 2003 | 11:18 AM
I bought a fuel pressure gage from Checker...
I primed the pump 2x and checked again: No fuel comes out when I depress the button to release the pressure on the tester, and nothing comes out when I depress the core of the schrader.
Old Aug 4, 2003 | 11:36 AM
kazman's Avatar
Replace your fuel filter.
Old Aug 4, 2003 | 03:25 PM
I did this too- No flow.
I replaced the fuel filter for some preventative maint while waiting for the pump to arrive from Summit...
EDIT: Replaced the pump and all is good again.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
Alex Barnes
Jan 24, 2015 10:21 PM
