Fuel Part Problem.
Old Jan 9, 2009 | 06:40 PM
SuperSport88's Avatar
Exclamation Fuel Part Problem.
I need some help from the pros here identifying a part. Came out from the store today to smell gas, and upon arriving in the garage, I looked underneath the rear of the car to see fuel dripping. I replaced the fuel pump back in the summer with the trap door method. It's not dripping from any of those lines that I can see from the opened door. Once I got it up on the lift, I found it leaking from a line between the fuel pump and the fuel filter. The thing is, its leaking from a white diaphram looking thing thats on a bracket about level with the axle, near the big square connecter is that I think is part of the ABS. I can't find a good pic anywhere, so I was wondering if anyone has a good pic of that area or has seen this before. I took the part out of the bracket, and it splits into two pieces where it has a spring and a tiny diaphramish thing. Once I took the bottom half off, I can hear it gurgling some and it allowed the rest of the fuel to come out. It's leeking pretty bad, and seems easy to replace, but I need a name and a part number because I doubt the guys at a dealership would have an idea as to what I'm asking for without one. Any help is appreciated and sorry for the long post. I'll continue looking for a good pic. Thanks.
Old Jan 9, 2009 | 06:42 PM
Sorry, forgot I didn't have a signature. It's a '95 Z28 with just mild bolt-ons.
Old Jan 9, 2009 | 07:27 PM
FINALLY I found a pic of it. https://www.camaroz28.com/forums/sho...fuel+line+pics It's in the third pic. Look at the metal bracket, and its the thing on the left of it. Its a squarish white piece that has a line coming in from the left side of the pic into it, and the line has the plastic shrouding on it. Sorry for posting a link, but I don't know of a way to repost someones pics. If anyone has an idea of the parts name or number, please help me out. Thanks.
Old Jan 9, 2009 | 10:13 PM
The vent valve? http://shbox.com/1/fuel_pump_wiring.jpg
GM PART # 10245442 for the white, plastic piece.
Old Jan 9, 2009 | 10:33 PM
Exactly. Thanks a million. You're the man shoebox.
Old Jan 10, 2009 | 11:35 AM
Helpful hint - when you post a problem, and someone provides you with the info you need, do NOT delete the thread. Leave it there so others can find it with a "search" when they have a similar problem. Shoebox took the time to help you, then you deleted his work. Not very considerate.
Noenav
Mar 1, 2019 07:38 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
nophix
Nov 30, 2014 10:26 PM
