fuel lines under the car question
Old Jan 31, 2013 | 09:18 PM
1badasZ's Avatar
Right under the driver's door where the fuel lines run, where you have the 3 lines. 2 of them have the snap connectors and one is a plastic line connected to a metal line with a little rubber hose, what is that line for? The lil rubber connection hose was dry rotted n bout broke in 2 pieces
Old Jan 31, 2013 | 10:33 PM
jloshotz's Avatar
One should be feed, one is return, the one with the rubber hose is most likely vent. I noticed mine was gone when welding in my SFC's, just replaced it with a small piece of reinforced fuel hose, all well
Old Feb 1, 2013 | 12:00 AM
Re: fuel lines under the car question
The "third line" in the fuel line bundle is the line from the charcoal canister in the drivers side rear fender to the EVAP vacuum purge solenoid on the bracket on the passenger side of the intake manifold.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
pologreen97z
Dec 2, 2014 10:42 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
