fuel lines and pressure guages
Old May 19, 2004 | 07:02 PM
djlunchbox's Avatar
here's my delema guys, i'm installing a new LT1 stroker into my truck, and i want to plumb the fuel system correctly, keeping the quick connects at the regulator intact. before i pulled the LT1 out, the fuel lines were cut and spliced with rubber hose and clamps, i would like to run earls fittings and hose from the fuel filter (drivers side frame rail) to the quick connect, and do the return line the same way. i also want to add a fuel pressure guage to the mix for when it goes in for tuning. if i can't do this easily, i'll just have to get the fp guage that screws onto the rail, but i wanted to keep that port on the rail open, and have a guage in there at all times. if anyone can help, or has part #'s for me that would be a great help. i'm swamped with trying to get everything i need orderd and here in time for the engine to go back in. thanks in advance
jeremy
Old May 20, 2004 | 12:45 PM
djlunchbox's Avatar
bumpity bump bump
Old May 20, 2004 | 08:04 PM
slopokrodrigez's Avatar
Don't see how or why you want to keep the quick release connectors. I used compression fittings to attach the braided fuel line to the regulator and the fuel rail barbs. Worked out fine, had to take a trip to Lowes and work out the pieces but I carried the extra fuel rail assy with me.
Old May 26, 2004 | 07:05 PM
djlunchbox's Avatar
thanks for the reply, that's what i decided to do. appreciate it.
Old May 26, 2004 | 09:02 PM
ASTROJOE LT1's Avatar
I had some new bungs Tig welded into the rails and plumbed mine with AN fitting.
Old May 27, 2004 | 08:15 PM
djlunchbox's Avatar
hmmm.....that's an idea too.... got any close up's of the weld ? and how do you like that regulator... i was told by another member that i didn't need a regulator, the stocker will work with a proper tune. this is for a LT1 stroker, 10:1 compression, 30 lb. injectors.. 1 person said stay stock, and one said get an adjustible reg. what does everybody else say? i'm being very careful to get everything right the first time, i only want to do this once
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
