Fuel lines
Old May 1, 2009 | 10:05 AM
Ian marshall's Avatar
Fuel lines
Can any body help with getting the fuel lines back on to the fittings (barbed metal) just before the regulator on a 94 LT1 I have taken the lines off and now can't get them back on, Help
Old May 1, 2009 | 12:36 PM
Kevin Blown 95 TA's Avatar
Put a little oil on the o-rings or the mating hard line and they should snap back together a lot easier if the o-rings aren't damaged.
Old May 6, 2009 | 03:25 AM
Thanks for that, however I don't think I have explianed myself very well. what I mean is pushing the black plastic fuel line over the barbed fitting just before the 90 degree bend that then goes to the quick release fitting before the regulator,
Old May 6, 2009 | 12:11 PM
You might need to heat that fitting up and push it in there. Not sure if you need to heat the line a bit - I havent had to do in 9 years - I'm sure someone else will know - also there was a couple fuel line threads going on in the fuel forums.
Old May 6, 2009 | 10:49 PM
If its loose, just get a new fuel line bundle. They are not very expensive. Hoping the plastic line will stay on the barbed fitting might risk an engine fire.
Old May 7, 2009 | 04:26 AM
Thanks for that, I have done exactly that and ordered a set from an Ebay guy in Florida, they should be here in about a week or so, but thanks for your imput
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
