Fuel lines
Fuel lines
Can any body help with getting the fuel lines back on to the fittings (barbed metal) just before the regulator on a 94 LT1 I have taken the lines off and now can't get them back on, Help
Thanks for that, however I don't think I have explianed myself very well. what I mean is pushing the black plastic fuel line over the barbed fitting just before the 90 degree bend that then goes to the quick release fitting before the regulator,
You might need to heat that fitting up and push it in there. Not sure if you need to heat the line a bit - I havent had to do in 9 years - I'm sure someone else will know - also there was a couple fuel line threads going on in the fuel forums.
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
