Fuel line questions, conversion from stock to AN
Old Apr 22, 2006 | 12:12 PM
snod83's Avatar
I was wondering if there is an easy way to convert the stock fuel lines on the car to accept an AN fitting, or any type of push in fitting to connect a line to it to run it to a pressure regulator. I am converting a stock 94 car to run with a carb and I am trying to figure out how to hook the stock fuel lines to a pressure regulator.
Thanks in advance,
Ryan
Old Apr 23, 2006 | 08:39 AM
LT4383's Avatar
Re: Fuel line questions, conversion from stock to AN
Thanks in advance,
Ryan
Russell makes some adapters, but last I heard they are on back order
part no. 640850
640860
Old Apr 24, 2006 | 10:40 AM
snod83's Avatar
Those actually push onto the fuel rails. I am looking for something to push into the fuel lines and hook an AN fitting to.
Thanks,
Ryan
Old Apr 24, 2006 | 10:49 AM
Earls makes compression fitting that will work. The fitting attaches to the hard line with a compression ring, and has a -6AN connection for the fuel lines. I believe they have them in both 3/8" (supply) and 5/16" (return).
cmdeshon
Dec 27, 2014 10:06 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
cmdeshon
Dec 12, 2014 10:51 PM
Jul 4, 2005 05:00 PM
