fuel line help
Old May 15, 2006 | 01:35 AM
Daniel6718's Avatar
fuel line help
who knows which fuel line under the passenger compartment goes to which fuel line on the rail??? i need to know because i just replaced mine
thanks
daniel
Old May 15, 2006 | 09:33 AM
Re: fuel line help
The larger fuel line (3/8") is the supply line, and connects to the passenger side fuel rail. The smaller fuel line (5/16") is the return line, and connects to the fuel pressure regulator at the back of the drivers side rail. The "3rd" line in the cluster is the EVAP canister purge line, and connects to the metal U-shaped tube about midway back between the drivers side of the intake manifold and the valve cover.
Old May 16, 2006 | 01:08 AM
Daniel6718's Avatar
Re: fuel line help
hmmm i understand where they hook up top to the fuel rails but i was getting at under the drivers compartment...im assuming the metal lines are differant sizes also???
HectorM52
Jul 30, 2017 11:46 AM
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
