Fuel line connections
You talking on the fuel rail im guessing? Just to clarify for people that might know the answer. If you are I dont think so, they dont seem like connections you can put on yourself, but I might be wrong.
Ahhh...What you might want to do is go to the junkyard and try to find an LT1 and just cut off the lines and either try to splice them together with the existing, or maybe reuse the fittings. But I doubt if you go to a GM dealer that they will have just the fittings. Try autozone though.
I'm in the same boat. I f-ed up the clips in mine, and can't seem to find anything aftermarket to replace them. You can get the entire part from GM (feed, return, and EVAP) from GMPartsDirect.com for about $45 plus about $45 oversize shipping.
87Aerocoupe
Mar 20, 2015 01:23 AM
Jul 4, 2005 05:00 PM
